motor mounts? poly, rubber, stock?
Old May 3, 2004 | 09:55 PM
CrAkD X 95TA's Avatar
rebuilding the engine with a hotcam kit, lt4 heavy duty timing chain kit, comp lifters and SLP headers gonna replace the engine mounts what do you think would work best?
Old May 3, 2004 | 11:05 PM
kmook's Avatar
Advanced Tech Moderator
I ran solids and liked them a lot. If you dont have a lot of vibrations to begin with you should be ok to run solids if you want to.
Old May 4, 2004 | 12:07 AM
Dave88LX's Avatar
Ken, do you know who will sell solids individually?
Old May 4, 2004 | 12:14 AM
RedHottG2's Avatar
Are solids ok for street use ? I was going to use polly, but if the solids are alright for the street that's what I'll use.
Old May 4, 2004 | 06:39 AM
kmook's Avatar
Yeash, why do you need only one? When i needed just a single ported maf end from thunder racing after loosing one they could not sell me just one, so advise me to contract mba who made them to see if i could get a single from the mfr directly. I know that moroso was the mfr or the ones i bought from summit, so maybe check with them?
Old May 4, 2004 | 06:41 AM
kmook's Avatar
I ran solids on the street when I had my SS.
Old May 4, 2004 | 06:52 AM
i had alot of vibrations before but i plan on replacing the entire suspension once the rebuild is complete.
Old May 4, 2004 | 06:49 PM
Dave88LX's Avatar
I bought a BMR tubular K w/ built-in mounts. The factory upper passenger side mount is already a solid, so no sense in replacing that. The lower is a poly.
On the drivers side, the factory upper is squishy metal. I can replace that with poly, or go solid.
I've got solids on my '88 LX and I love them.
That's the reason I only need one...
Old May 4, 2004 | 08:10 PM
dnz28's Avatar
soild mounts
motor plate=
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
