Motor mount Bolt and Bracket Bolt
Old Mar 24, 2004 | 07:31 PM
ponyackn's Avatar
Angry Motor mount Bolt and Bracket Bolt
The driver's side motor mount bolt has another mounting bracket bolt lined up perpendicular to and right in front of it, leaving little to no room to put socket on. Did you guys have to remove that one perpendicular bracket bolt first?
Old Mar 24, 2004 | 08:18 PM
It's one of those things when each is in the way of the other, no matter what sequence you use. If you tilt the rear of the engine down (lower the back of the tranny), the bolt going into the block will be out of the way of the motor mount through bolt. The motor mount should flex enough to make this work.
Old Mar 24, 2004 | 08:20 PM
96speed's Avatar
I ditched that bolt a long time ago. Life has been easier since .
Ryan
Old Mar 24, 2004 | 08:29 PM
ponyackn's Avatar
I'm just glad people actually new what bolts I was talking about. Well, i don't really want to go thru removing tranny stuff again to drop the tail. I think I'll try removing the bracket bolt first, then the motor mount bolt. Correct me if this is not possible.
Old Mar 24, 2004 | 10:52 PM
The bolt that goes into the block that interferes with the motor mount through bolt is a bolt for the motor mount bracket (if I remember correctly). IMO, that bolt should not be left out. You will just have to play with it and see what you can do.
Old Mar 24, 2004 | 11:02 PM
97WS6SCharged's Avatar
I hooked up my cherry picker and lifted the engine slightly to get the bolts where they weren't touching each other.
Old Mar 25, 2004 | 12:28 AM
96speed's Avatar
I also left out one of the belhousing bolts (Anyone with a T56 knows which one). Some bolts are just not very nice!
My engine never fell out, so it must be ok, right?
I definitely wouldn't recommend leaving any bolts out though. Be careful...
A motorplate solves this problem.
Ryan
Old Mar 25, 2004 | 01:02 AM
ponyackn's Avatar
That's true. But I figured since there are 2 bolts for the mounting bracket, removing one should be all right. I can remove that first, then remove the mount bolt, lastly, reinstall that 1st bolt.
96 Speed, I was told as well, to leave the top 2 bellhousing bolts off. Even thought I didn't do that, I know that the shop that worked on it b4 me apparently left a bottom bhousing bolt out.
Thanks for the help guys. Wish me luck tomorrow.
Old Mar 25, 2004 | 04:16 AM
94m5's Avatar
I'm not a big fan of leaving any bolt out of an engine/tranny combo. I figure that the parts were put there for a reason and should be kept there. Like was said previously, pull up on the engine with a Picker, and you should be gravy.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Cam's maro
Jan 8, 2015 05:01 AM
thenewkid
Nov 18, 2014 12:57 PM
