motor is locked up and will not spin
Old Aug 20, 2006 | 02:05 PM
  #16
Dave89IROC's Avatar
Re: motor is locked up and will not spin
Originally Posted by SS RRR
hydrolocked from what?
fuel(stuck injector) or coolant(head gasket)
Old Aug 21, 2006 | 05:39 PM
  #17
Ws6Envy's Avatar
pulled the plugs, still seized....
drained the oil and 3.5gal of oil and coolant came out.
whats the next step???pull the heads and see whats salvagable???
Old Aug 21, 2006 | 06:30 PM
  #18
bmwmcars's Avatar
wow, that really sucks. i guess i would be pullin the motor and startin over.
did you install the heads? if so, did you use thread sealer on the bolts/studs? they go through water on sbc's. i have heard of guys not doin that and ******* their bearings real quick.
Old Aug 21, 2006 | 06:35 PM
  #19
Ws6Envy's Avatar
yes, i absolutly used thread sealer on the bolts. i remember the warnings
but thanks for the reply
Old Aug 21, 2006 | 06:46 PM
  #20
klrz28's Avatar
"time to do a 434 while you got it out this time " git er DUN! ill sell you my 383 got 1000 miles on new block
Old Aug 21, 2006 | 06:56 PM
  #21
Z95m6's Avatar
Originally Posted by oneslowz28
sounds like whoever assembled it used motor oil instead of assembly lube. my friend just had this happen to his fully built carb 350 that cost 4k. the builder uses motor oil instead of assembly lube and right around 1000 miles one of the pistons exploded and we noticed that all of the berings (rod and main) were chewed to peices. and the rod from where the piston exploded had almost no berring at all was left. when we contacted the builder he claimed to have no responsibility for the problems and when i called back and acted like a intrested customer i asked what he used for assembly lube and he said that all of his builds use motor oil for assembly lube. well thats all fine if you plan to start the engiine 30 min after its built but if it takes 3-44 weeks like it did him then all of that oil has seeped back out and left nothing but metal to metal contact
So you're saying that if a car sat in storage for a month or two the motor would just grenade on start up because all the oil "seeped" out? Damn i had better not start my Mach 1 up, its been sitting since April with out being started.
Old Aug 21, 2006 | 07:46 PM
  #22
Kreinmc's Avatar
Did you check the starter? I would check that first and then the timing chain.
Old Aug 21, 2006 | 07:54 PM
  #23
Evil Eric's Avatar
assembely lube was used for certain.
the starter is off the car right now and still will not manually turn
I've been down that road, draining the oil almost always tell's you what the culprit is. You're screwed, pull the heads.
Old Aug 21, 2006 | 10:05 PM
  #24
bmwmcars's Avatar
he took the starter out a few days ago
Old Aug 21, 2006 | 11:14 PM
  #25
razor02097's Avatar
so the block probably cracked? Before you pull the motor can you get the oil pan and heads off?
Old Aug 21, 2006 | 11:21 PM
  #26
HardcoreRM125's Avatar
No, the head gasket probably blew out. The most common cause for a failure so soon, would likely be not tightening the heads down in the right sequence. Also, you should "asquish the gasket down by torqueing the heads down a couple times on a ML head gasket. I would think something laong these lines is explaining it. Or somethign that caused abnomally high cylinder pressures and was enough to blow the gasket but the forged parts took it though
Old Aug 22, 2006 | 10:07 PM
  #27
pearlpurple's Avatar
you read my mind only I don't have a Mach 1
I guess I have been lucky last couple of years when starting mine up in the Spring
However I too recommend assembly lube as it is a very good insurance policy if you have start up oiling problems and you catch them right away you may save your engine. You know how that very first start up is a nervous one even if you primed the oil system. Guages get watched like a hawk and you are looking for leaks on thegarage floor like every 10 seconds
Old Aug 23, 2006 | 04:24 AM
  #28
redcamaroz28's Avatar
I was in the car in the process of tuning it when this happened. Not 5 minutes before this happened everything looked ok according to the datalog. (I am still attempting to pull the log off of my laptop since the Adrive doesn't work, and will post it whenever I do so). The timing table was based off of my car which has a smaller cam and stock displacement, so there is no chance that it was detonationg as my timing was not excessive. It was also running negative BLM's (computer pulling fuel out), so it did not see any lean conditions the whole time leading up to when it seized.
Rob, please keep me updated with what you find if/when you pull the motor apart.
Ryan
Old Aug 24, 2006 | 05:09 PM
  #29
Ws6Envy's Avatar
pics....
http://www.fuelslut.net/hosting/uploads/IMG_2947.JPG
http://www.fuelslut.net/hosting/uploads/IMG_2948.JPG
http://www.fuelslut.net/hosting/uploads/IMG_2953.JPG
http://www.fuelslut.net/hosting/uploads/IMG_2954.JPG
http://www.fuelslut.net/hosting/uploads/IMG_2952.JPG
Old Aug 24, 2006 | 07:33 PM
  #30
SS RRR's Avatar
pics....
yeowch... have you found out the cause of the broken valve and why there's coolant in the oil pan?
