Motor delema: WHAT TO BUILD
Old Sep 18, 2008 | 07:33 PM
hvyss's Avatar
Motor in my Impala is coming out this winter. Don't know if I want to stay 355 or build a 383. Car is running good on a 355 with a cast Eagle crank, 5.7 Eagle SIR rods, and SRP flatops. Car is running mid 11's on a 150 shot but don't want to push it much more with the cast crank. I am getting a set of AI 200cc heads to go with the new setup and forging the rotating assembly to add more nitrous. I just don't know if it worth the extra machining and money for a 383. As far as a cam I am going with an AI street solid roller. Would like to put the boat in the 10's but don't if I can on a 355. What do you all think? 355 or 383. Remember the car weighs in at a portly 4400 with me in it.
Old Sep 18, 2008 | 09:38 PM
user 647483's Avatar
383 is going to give you more options later on, but it's also going to make the build
a little more expensive at the machine shop. Either way, do it right and don't cut corners.
A well-built 355 is better than a 383 done on the cheap anyday (even more so as time goes on)
Old Sep 19, 2008 | 02:03 PM
ulakovic22's Avatar
If you can afford to go forged 383 then do it. 355's are good motors and being a solid roller can make a lot of torque to get that thing moving. Ported stock castings on a 355 should be nice, not sure how much air a 383 would need though. I personally don't think you can go wrong either way.
Old Sep 19, 2008 | 04:57 PM
96' Formula WS6's Avatar
I think 200cc heads would be a little small on a 383. If you build a 355 right you can get well into the 10's, especially if you juicing it a little.
Old Sep 19, 2008 | 08:10 PM
hvyss's Avatar
I was leaning toward a forged 4 bolt slayed 355 by want some ideas from other 355 and 383 people before I make my final decision. I think it would be neater to say I have a 10 sec Impala SS with a 355 than a 383 but if the 383 is better to help get the boat out of the hole then I don't know. Keep the comments coming.
Old Sep 19, 2008 | 09:02 PM
WS6T3RROR's Avatar
You're buying a new crank anyways get the longer arm. The extra machine work of a 383 doesnt amount to spit compared to the total cost, you can even do it at home if you dont suck. Cubic inches = hp/tq, just remember its a 383 when you're picking the parts. Tell you what call up ai and ask them what they think you should do.
If i was doing it again I have no doubts I would do a 383, i am right up on the 7000rpm limits of the stock pcm as it currently sits. I have my old short block in the garage that i'm going to start making into a stroker.
Old Sep 19, 2008 | 10:27 PM
87bandit's Avatar
check a/i's website under customers cars you can get an idea of different head combos in SRs
a budget 355>budget 383
if you're going aftermarket crank tho I see no reason why not to go 383
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
Cam's maro
Jan 30, 2015 09:21 PM
