Most lift on stock springs?
Old Nov 14, 2004 | 02:09 PM
Sneakin Deacon's Avatar
what is the most lift the stock springs can handle?
Old Nov 14, 2004 | 03:05 PM
WS6NIGHTMARE's Avatar
Re: Most lift on stock springs?
I looked into this a while back and I dont remember where I read it but I beleive they coil bind at .500
Old Nov 14, 2004 | 03:22 PM
96capricemgr's Avatar
This is a question that should not even be asked, they are not great springs and these are not new cars. So what you have is springs OK for a stock cam when new that are now 7+ years old, pushing their lift limits now will result in float. A set of LT4 springs will get you more lift capacity a little more pressure and I think they cost a whole $35 a set, those are still not going to be any good for many of the popular cam choices but should be OK with a stock cam and higher ratio rockers. If worried about the trouble of a spring swap on the LT1 it is not that bad, bring the piston to TDC and the valves only fall a quarter inch at most meaning you do not need air to hold the valves up.
Old Nov 14, 2004 | 03:26 PM
Hey!! the man didnt ask for all that!!
j/j ....... dont hurt me
I agree, springs dont cost that much and it will give you something to do for a while. But i beleive my answer was still correct.
Old Nov 14, 2004 | 03:29 PM
Spinner's Avatar
Most lift that you should ever apply on stock springs is stock. Dont touch anything unless you get rid of the springs for something stronger.
Old Nov 15, 2004 | 02:30 AM
i found it on a fiero site, .490 is the highest rated lift. i was just trying to find out cause i came across a set of 1.7 RR's that i figured i could invest in...but i think ill be saving the spring swap for when i do heads/cam. thanks for the input.
Roadie
Feb 16, 2015 10:34 AM
Cam's maro
Jan 30, 2015 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
