Moroso solid motor mounts: HELP!
Old May 22, 2003 | 02:23 AM
Dr. Weir's Avatar
Well, I did what Jeg's said and ordered part #710-62510 and #710-62635. If someone who has done these could PLEASE tell me how these 2 pieces fit together, I'd really apreaciate it! I am starting to think they sent the wrong parts.
Old May 22, 2003 | 02:46 AM
Dr. Weir's Avatar
Ok heres a pic.
As you can see, the 2 parts seem to be of different sizes. I double checked the part numbers, and according to Jeg's, they are right!
Old May 22, 2003 | 10:37 AM
Mr. Z28 73/97's Avatar
The way it works is like this the larger pieces in the picture replace the mushy rubber bushings and they bolt to the k-member then you use your stock block mounts.
Old May 22, 2003 | 10:51 AM
Ghettoraid's Avatar
If all else fails, buy like half a dozen hockey pucks, get out your drill and belt sander....
Should work just as well if you don't fear getting your hands a little dirty...
Old May 22, 2003 | 11:50 AM
red's Avatar
red
I don't know why they told you to get the #62510. The other two that are not in the package are the mounts you need to use. Like said before they replace the rubber mounts. They mate up to the solid mounts that are already on the motor and on the K-member. One side will bolt to the block and the other will bolt to the K-member. I forget which side is which.
Old May 22, 2003 | 09:54 PM
Dr. Weir's Avatar
Thanks guys, this will help greatly. Now, I just need to figure out how to get out the rusty motor mount bolts!
thenewkid
Apr 12, 2015 07:42 PM
cmyname1
Feb 19, 2015 08:38 PM
thenewkid
Nov 27, 2014 09:41 AM
Nostang 96z
Aug 31, 2002 12:01 PM
guionM
18
Jul 11, 2002 01:45 AM
