Moroso 20185 oil pan
Old Jun 21, 2007 | 08:27 PM
lincoln8's Avatar
Does anyone have this oil pan and are there any issues regarding headers...etc? I am doing a heads-cam change and would like a larger pan and windage tray. I have edelbrock mid's and a M-6. Any info would be appreciated.
Old Jun 21, 2007 | 10:08 PM
The Engineer's Avatar
I have the Moroso LT oil pan w/ Kooks headers and they fit just fine together. However, you'll have to plug the "Low-Oil" sensor port, it can't be used with the Kooks headers.
The starter is more difficult to remove with the Moroso pan.
Also, my Moroso pan had two separate leaks from the factory (missed and bad welds). Therefore you should fill it with a thin oil diesel or kerosene and check for leaks prior to installing it.
WD
Old Jun 22, 2007 | 03:21 AM
95ttoplt1's Avatar
I have that pan and have no cleance issues at all. Clears the K-member and everything.
HectorM52
Jul 30, 2017 11:46 AM
jl1ne
Jul 7, 2015 08:38 PM
SergheiS
Jul 5, 2015 03:27 AM
Koby
Jun 28, 2015 04:46 PM
SergheiS
Apr 26, 2015 08:15 PM
