more starting woes
Old Feb 3, 2005 | 05:45 PM
Sooner94Z28's Avatar
more starting woes
OK, a while back I posted about my car not starting. New starter/battery/cables/etc... later, it still does the exact same problem but I have more observant info. I'll turn the key, but the security light in the guage area stays on. Once it goes off, usually about 4-5 minutes, I can start the car and go about my business. Lately it has been getting worse and worse and sometimes does it to me 3 times in a row before it starts. the Captain Obvious side of me says it is the factory security setting that is screwing up, yet I have no idea how to go about fixing this. Should I take it to someone or is it easy enough to do myself? (the latter part of that question is almost laughable) thanks in advance for any help.
Old Feb 3, 2005 | 06:01 PM
Robs97Z28's Avatar
Re: more starting woes
it is one way of checking the the vats is working correctly: http://shbox.com/1/vats_bypass.jpg
It might be the key or it might also be the ignition switch.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
