More Help....
Old May 31, 2004 | 04:31 PM
Koby's Avatar
More Help....
So I just got done doing my intake leak fix, I deleted my egr, and I also changed the thermo out while I was at it. I got a new thermo from autozone. Now that everything is bolted up and in the car runs fine but the cooling fans never kick off. They run constantly. they will shut off for like 30 seconds and then come back on. I am getting an SES light when the fans are on and when the fans turn off it goes away.
The thermo stat the guy at autozone gave me looks nothing like the on I pulled out of my car. Could that be the problem? If the thermo won't open wouldn't the fans stay on all the time??
Old May 31, 2004 | 04:37 PM
94zLT1's Avatar
our thermos are a special REVERSE FLOw THERMOSTAT he sold u the wrong thermo...make sure it is reverse flow
jkipp84's Avatar
Common Autozone mistake. I believe you can get the Hypertech thermostat through them though, you just have to specify that's what you want.
Old May 31, 2004 | 04:38 PM
Hawk's Avatar
The LT1 thermo is different then a SBC chevy thermo.
It sounds like you got the wrong thermo, I'd get the right one.
Brian
Old May 31, 2004 | 04:41 PM
Koby's Avatar
Thats what I thought but I wanted to be sure before spending anymore money on stuff.
Thanks guys.
Old May 31, 2004 | 05:28 PM
Koby's Avatar
Ok I got the new thermo stat and it didn't help. I know the thermo is right though, but the fans still kick on and I still get the SES light everytime they come on......could have forgetten to hook something back up when I put the intake back on???
Old May 31, 2004 | 05:41 PM
94zLT1's Avatar
bleed 2 bleeder screws...waterpump may be bad...if u had a aldl cable and labtop u could scan it
Old May 31, 2004 | 05:43 PM
94zLT1's Avatar
oh i thought u were overheating...nevermind that last post besides the scan...disconnect your neg. battery terminal for 10 min then rehook
Old May 31, 2004 | 06:02 PM
Koby's Avatar
reset pcm...still does it.
Old May 31, 2004 | 06:53 PM
The thermostat would not have caused the SES. Maybe you left something disconnected. If you cannot find anything, you need to get it scanned to see what the SES is about. Don't know what all you did to delete your EGR, but it could be related to that.
BTW, the fans come on because of the SES. That's normal and supposed to be that way.
Old May 31, 2004 | 07:10 PM
Koby's Avatar
Yeah I deleted the egr, as of right now only the canister and the module were deleted. I still have to delete the tube from the manifold to the intake. I know that deleting the EGR causes an SES light....but do the fans come on from that? If thats the case I am about to invest in a PCMforless tune...
I am takin it to autozone tomorrow to scan for codes...hopefully it is only the EGR.
wildracer
Jul 30, 2010 12:49 PM
ttop1997
Jun 18, 2010 11:27 AM
AlwaysCode390
Oct 30, 2009 05:28 AM
sick9lt1
Aug 25, 2009 01:55 PM
1994TransAm
May 29, 2007 08:14 PM
