More air for k&n filter???
Old Oct 18, 2003 | 02:04 AM
  #16
Critter's Avatar
yeah you need cheap quick power......change the fuel filter.......i just did it and i felt a diff. top end.......of course it hasn't been changed since 99'...maybe that had something to do with it........just a thought
Old Oct 18, 2003 | 02:20 AM
  #17
Fatdog's Avatar
Cool
Actually the white dryer hose works pretty well,but only on the outside of the filter,not from the filter to the bellows.A better flex tube can be had a Pep Boys,part #96007,called mighty flow air duct hose.Actually abetter filter can be had from any Kragen auto parts store or rice store,looks the same size as a K&N,but has a filter at the bottom of it as well(more air flow).about $29.00 or so.Just duct tape(use the $9.00 duct tape as it is really sticky),to the bottom of the filter,and you may be impressed I dunno.Gotta clean it more often though ,as you can suck up a lot of dirt fast.I don't understand why anybody would come down on anyone here for a new idea,as this is a help board.Hope this helps.
Imagination+trial and error=results,sometimes good,and sometimes not.But you won't know till you try.My02
Old Oct 18, 2003 | 07:23 AM
  #18
CamaroGuy22's Avatar
I agree!
Old Oct 18, 2003 | 07:27 AM
  #19
bad1LEz's Avatar
My .02$. I cut a big hole out of my bottom panel, directly below my K & N. Then attached a stainless screen over the hole to keep large stuff out. I noticed no HP gain or "feel", however, I now here the rush of air going into the filter-elbow-TB when I mash the gas. I know it's now getting more air. Enough air? I doubt it, but more. Tried the dryer vent "scoop" but my damned car sits too low. In the process of fabbing a low profile bent aluminum piece to bolt onto the bottom.
The idea about the dryer hose ABOVE the plastic piece directing air directly to the filter is a good idea. Would like to hear more on this.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kksi
Mar 21, 2015 09:03 PM
95chwagon
Jan 13, 2015 09:19 PM
stanghunter211
Aug 29, 2002 03:04 AM
