is monoblade reliable?
Old Jan 26, 2006 | 07:08 PM
DiabloGT's Avatar
cause i seen problems with them if i go off with fully ported afr 227 heads/cam and maybe later id go with a turbo along with that would 58mm be good enough for like at least 700rwhp?
Old Feb 1, 2006 | 07:32 PM
DiabloGT's Avatar
Re: is monoblade reliable?
ttt
Old Feb 1, 2006 | 09:16 PM
ajschult's Avatar
I've never heard anything bad about them, but you probably don't need to spend the money. 58mm should get the job done.
Old Feb 1, 2006 | 09:22 PM
96speed's Avatar
A monoblade is plenty driveable. It is a mechanical part and will fail eventually. However, any throttle body shares that description.
What problems have you seen?
Ryan
Old Feb 1, 2006 | 09:54 PM
LT1 EXPRESS's Avatar
I have a srizona speed marine 58 mm throttle body im lookin to sell u intrested
Old Feb 1, 2006 | 09:55 PM
TQdrivenws6's Avatar
There are two reasons not to get a monoblade from what I've seen.
1. Blower cars tend to push them open at idle
2. The IAC no longer travels through the passages and typically can lead to split BLM's
That being said, there is a monoblade on my car. I don't ever plan to supercharge it and I have gotten the low rpm tuning done so the BLM's are good enough for my tastes. If you are going with a high rpm 383 or bigger, its almost necessary to go bigger than a 52mm unit.
Old Feb 2, 2006 | 10:14 PM
DiabloGT's Avatar
i have heard something like the spring broken and the blade not moving? i forgot but i seen a couple problems people posted about it, and someone did a mod for it. but jw will 58mm be enough to handle about 1000rwhp for a turbo car or no
RUENUF
Mar 13, 2016 03:37 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
WPHIG2
Aug 27, 2015 06:37 AM
