Monoblade with an LE2??
Old Nov 19, 2006 | 10:18 PM
Formula WS6's Avatar
I have the opertunity to purhcase ASM monoblade TB. My question is, is anyone running a monoblade on a stock bottom end LE2 h/c car? My guess is it's a little overkill. I'm currently running a 52mm BBK that I ported and polished slighlty.
thanks
Old Nov 19, 2006 | 11:47 PM
turbo_Z's Avatar
There is such considerable work in making it fit the intake that I wouldnt ever consider buying one. Plus you have to cut out the main IAC port on the intake which could result in poor idle quality. They sure look nice though.
Old Nov 20, 2006 | 07:47 PM
Thanks for the input, I have a buddy who knows how to fix the iac problem and My intake is already cutout for a monoblade. I did it when I ported the intake. My only concern if it's not necessary or overkill to where I'd end up loosing power.
Old Nov 20, 2006 | 08:52 PM
1 slo 6's Avatar
u would get a better throttle reponse but it all depends on the cam size u go with in terms of power loss.....
Old Nov 21, 2006 | 10:36 AM
1redTA's Avatar
re
I was under the impression that most dry manifolds get better hp/tq from bigger throttle bodies
Old Nov 21, 2006 | 02:38 PM
LT4POWR's Avatar
I got one (yes, overkill, but I got a good deal on it) with an LE2(ish) cam. My intake was ported by Bret (BRE) and I've got no problems.
Old Nov 21, 2006 | 07:55 PM
Would you not recommend it then. or is it no big deal?
Old Nov 23, 2006 | 05:04 PM
LT4POWR's Avatar
It's no big deal, driveability is fine, but I think you don't really "need" one (over a 52mm) until you've got a high rpm stroker motor.
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Schul365
Aug 25, 2015 05:47 PM
MAKQSIK
Parts Wanted
Jun 11, 2015 04:30 PM
Nutty's96
Parts Wanted
May 12, 2015 09:37 PM
