CamaroZ28.Com Message Board
-   -   Monoblade (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/monoblade-281870/)
MEAN LT1 Jul 14, 2004 10:25 AM
Monoblade
Im considering getting a Monoblade to upgrade from the stock throttlebody. Ive heard back in the day when they were new that they were having idle issues. Has that problem since then been fixed. has anybody had any trouble from there monoblade?.
Dave88LX Jul 14, 2004 10:54 AM
What in the hell do you have done to your car that requires you to use a monoblade?!?!:confused:
EDIT: Just saw the blower in your sig :) I still want to know at what point one needs to switch from say the 58mm to a mono...
MEAN LT1 Jul 14, 2004 11:12 AM
Well if you goto the advanced section, they had a pretty good thread that discussed this in fine deatil. One of the points that I grasped and remember is that its better to go too big than too small. Basically saying is that a stocker t/b will hinder a max effort application's hp but a simalar setup will not be hindered by a t/b that is bigger than needed. The motor will only engest what it can consume.:)
Dave88LX Jul 14, 2004 11:20 AM
Max flow of the P600B is 1200cfm (http://www.procharger.com/models.shtml)...Maxflow of the 58mm is 1050 cfm, monblade is 1300cfm if I remember right. Yikes. Thats a lotta damn air LOL.
Have fun with it! :)
MEAN LT1 Jul 14, 2004 12:21 PM
Yes, this is true, Im kind of getting ready for the next setup even though my current one isnt finishes, Im trying to buy things that leav room to grow. The huffer that I'll be purchasing will be an F1 which pushes 1,525cfm.
kmook Jul 14, 2004 12:27 PM
I have one waiting to go on. I talked to Brent about it, and he said he sold his to a buddy who has a stockish car and he doesn't have any idle issues...
quicksilver97ta Jul 14, 2004 01:21 PM
No problem with split blm's? I remember Brent doing a mod on a 58mm t.b. to isolate the IAC passage like the stocker. I still have the stocker and wonder how much the IAC passages in the intake may contribute to REVERSION and consequent "CAM SURGE" that refuses to completely go away. Maybe I should abandon the IAC passages in the intake the way that monoblade does. :think: I do have the BLM locker now. ;)
MEAN LT1 Jul 14, 2004 01:24 PM
Yea, When i was doing a search ont he monoblade I read your post in which you and Brent were talking about it. I guess since I havent see any begetive post I'll go ahead and pick it up.
SAR2K Jul 14, 2004 01:30 PM
Been running a monoblade since last year and have never had any idle issues with it.
Steve...
Mindgame Jul 14, 2004 02:23 PM
Going small can only hurt things on one of these engines. Even the posts I've seen showing swaps from stocker to 58mm on near stock engines have showed negligable gains. Which tells you right there that the power increases will be proportional to the engine output and going bigger isn't going to hurt.
quick,
Check those IAC passages the next time you pull the intake. A couple of the holes on my buddies intake were quite a bit smaller than the others. That can't be helping the situation.
-Mindgame
quicksilver97ta Jul 14, 2004 02:33 PM
Originally posted by Mindgame
quick,
-Mindgame
:eek: Actually I did, and there was only one that was smaller so I opened it up to match the rest. I just wonder about the LACK of idle air moving in the MAIN intake runners.
MEAN LT1 Jul 14, 2004 03:24 PM
There used to be a good thread about when to switch over to a bugger t/b. I thought it was in the advaced section but I cant seem to find it. Anybody have it archived or know where it is?.
kmook Jul 14, 2004 03:30 PM
This one?
http://web.camaross.com/forums/showt...threadid=31034
or
http://web.camaross.com/forums/showt...hreadid=130974
MEAN LT1 Jul 14, 2004 03:45 PM
Those are both it, i thought it was just one thread but those are it. Thanks Ken.
