Modded????
Old Apr 24, 2005 | 02:39 AM
FORD_IMPORT_HATER's Avatar
Modded????
I recently purchased a 96 Z M6 from a dealer. The engine was rebuilt as well. I noticed this Z is quicker than my 96 Z A4 I had before it was stolen. I have and air foil and an aftermarket MAF. This is were my quesion comes into play.... When I'm in 1st or any other gear for that matter, when I reach about 3500 - 4000 RPM's I notice a whining noise like as if I had a blower in there. There is no mechanical failure whatsoever. In fact if I were to punch it I will spin my tires. My question is, Is that normal on an M6 or do I have some type of cam of some sort. It does not lope at all however, It has noticeable HP if I were to punch it from that RPM range. The whining noice is in question.
Thanks in advance.
Old Apr 24, 2005 | 04:13 AM
sssalah's Avatar
Re: Modded????
Well, the M6 eats less HP than the A4, that's why it feels faster. The whining sound could be the M6 internals going bad
Old Apr 24, 2005 | 11:30 AM
#7's Avatar
Re: Modded????
It could be the Alt. or the power steering pump. Get a stick,or breaker,stethoscope and try to replicate the sound in neutral fiddling with the throttle linkage at the thottle body and listening to some of the componants. Those kinda sounds drive me nutty till I find out what they are
Also the A4 and the M6 cars have a different rear gear. You are feeling the difference between 2.73 and a 3.42 rear gear(most likely,or 3.23 to 3.42) AND the lessened powertrain loss associated w/ the M6.
Old Apr 24, 2005 | 02:10 PM
Re: Modded????
Thanks for your imput. I'll try to locate tha whining.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
