Mixed ideas on head gaskets..
Old Jan 19, 2005 | 12:37 PM
flusz28's Avatar
Well i'am just have my stock lt1 heads ported and valve job done for my blower. now i figure i will go with felpro 1074's... other guys have said go with impala ss head gaskets... and some other types don't remember what. what should i use???? thanks..
Old Jan 19, 2005 | 01:36 PM
groundpoundinlt's Avatar
Re: Mixed ideas on head gaskets..
id also like to know whats the best to run
Old Jan 19, 2005 | 01:50 PM
kmook's Avatar
Advanced Tech Moderator
Well they are all different thicknesses to start, so for one consider how they will affect your c/r. I like the 1074 myself alot.
Old Jan 19, 2005 | 01:56 PM
i should have around 10.5 will the felpros work??
Old Jan 19, 2005 | 11:05 PM
redcamaroz28's Avatar
I put in an Impala head gasket just 70 miles ago since my old one blew. No problems so far, and I computed that my C/R is 11.0:1 by changing the gasket. Here are the compressed heights: Stock gasket-.049, felpro-.039, impala-.029, Mr. Gasket-.026.
Old Jan 20, 2005 | 08:01 AM
flusz28's Avatar
what would be the point to decrease the compression ratio?
Old Jan 20, 2005 | 12:03 PM
tryintogofast's Avatar
With a blower you would like to get the compression ratio down. This is becuase of detonation or ping. The lower you can get the compression ratio the less likely you're going to get some ping. Ping on a FI motor will break something very quickly. Most likely your ring lands.
Mikey
Old Jan 20, 2005 | 02:42 PM
ShawnMacAnanny's Avatar
So what are the thinnest gaskets i can buy? Not trying to hi-jack the thread, just curios. The Mr Gasket are the thinnest head gaskets made for the LT1?
warmeck
Mar 1, 2015 08:47 PM
armedtrigger
Feb 24, 2015 08:30 PM
pimpss96
Feb 12, 2015 01:28 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
