missing wire?
Old Apr 10, 2008 | 07:06 PM
97'Z-28's Avatar
missing wire?
sorry if i'm posting in the wrong place but I recently did an opti,timing chain,and oilpan gasket, and I noticed a wire on the ignition coil connector missing, the car runs ok, and I was wondering if you guys can help me out trying to figure out where that wire goes to.
here is a pic.
[IMG][/IMG]
Old Apr 10, 2008 | 08:43 PM
Oxygen454's Avatar
I have seen these connectors before. I believe it is a plug for an unused connection.
Old Apr 10, 2008 | 09:18 PM
ricehammer's Avatar
Looks like you only need 3 wires http://shbox.com/1/95_ign_system_schematic.jpg. I can't match the wire colors, but the wires are kinda greasy anyways.
Old Apr 10, 2008 | 10:32 PM
97'Z-28's Avatar
ok, thanks guys, sounds like its nothing to worrie about.
Old Apr 11, 2008 | 12:07 AM
3 is what there is for 94-95.
Old Apr 12, 2008 | 08:16 PM
Oxygen454's Avatar
No problem, I think there is some more connections if I remember correct under the hood that has these plugs. Seems like they keep the harnesses as the years go on but use different or less wires so they plug the no longer needed wire ports on the plugs.
HarleyZ28
Oct 5, 2015 06:23 AM
mattstrike
Mar 11, 2015 07:33 PM
armedtrigger
Feb 24, 2015 08:30 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
