missing bad
Old Mar 2, 2003 | 06:17 PM
certifiedlt1's Avatar
missing bad
ok guys i have a 95 z and i took my car to the automatic car wash today and nothin seemed to happen it drove home fine, i like about 2 miles from the car wash, well few hours later i start up my car let it run for 10 min, i always let it warm up, well i got in it put it in gear and it has this jerking action and its sounding really diff, like its missing, it has 65,000 miles , new plugs wires , and i put some shorty headers on it, but i dont think they woulda burned my wires, well with this info, anyone got any good guess's on what the prob could be
Old Mar 2, 2003 | 07:01 PM
mizzuut's Avatar
Mine did the same thing at about 70,000 miles. It sounds like the optispark is getting moisture on it. Mine did the same thing when I took it to the car wash. I got my optispark changed and fixed the problem. Maybe that will help.
Old Mar 2, 2003 | 07:28 PM
thanx for the help man
might as well try it, just dont really have that cash right now
Old Mar 2, 2003 | 08:06 PM
badgta's Avatar
try checking the simple things first, loose plug wires,spark plugs ( I found a cracked plug insulator on # 1 plug once, low rpm miss)
ALSO look under hood at night in as little light as possible, you may be able to see arching from plugs/wires/coil/ to block if so replace that item first ( cheap!!) i had taken apart the opti twice before finding wire arching wire - to - block . this will save time and aggravation, opti not to easy access .
Old Mar 2, 2003 | 08:31 PM
Poorboy94Z's Avatar
Hey, I had a simmilar problem. One day out of no where my car started missing and running real bad and if I got it started it would backfire and miss and pop. If I shut it off it would not start back up. I put new plugs and wires and 02 sensors in it. That did nothing. It ended up being the opti. Replaced that and now it runs great. Try everything else mentioned above because the opti is both expensive and is a pain to take out and reinstall. Good luck
jocamino
May 14, 2015 07:37 AM
markzzzz
May 8, 2015 09:21 AM
rideordie
May 3, 2015 12:53 AM
captcorvette
Mar 7, 2015 12:37 PM
DetroitZ28
Feb 13, 2015 07:33 AM
