Missing anything for a RR install?
Old Sep 10, 2004 | 02:41 PM
HardcoreRM125's Avatar
Ill be ordering sometime soon, but I want to make sure I have EVERYTHING I need. So heres what im ordering ...
Comp Pro Mag 1.6's 7/16"
ARP 7/16's studs
GMPP Guide plate
LT4 Hot Cam Springs.
Valve Spring compressor.
Is there anything else that I could possibly need to do this? Poly Locks or anything ??? I never did RR's before so this one's a learning experience.
Old Sep 10, 2004 | 02:46 PM
TransAmGT94's Avatar
Re: Missing anything for a RR install?
poly locks are nice but not needed are you doing a cam swap later down the road if so i would get a spring to better fit your cam choice instead of sinking money in lt4 springs like i did only have had them on the car about 4 months and have another set sitting in my room for the cam i choose
Old Sep 10, 2004 | 02:50 PM
LWillmann's Avatar
Thread sealer
Valve seals
Old Sep 10, 2004 | 02:54 PM
Yea ... I know ... It sucks dont it. I will NOT be camming this car for a while. Im in the process of saving enough money to build a forged and blown 383, So I was going to just have a custom ground cam made then whenever I slap a D1SC on there. But it will be at least 2 years until I can dish out that kind of money on the car, and I want to do that all in one shot if i can that way I get the most from the tuning so ... Arent LT4 Hot Cam springs only like 40$-ish from GMPP though? So it wont be a complete waste of money as I'll be running a mostly bolt-on setup fora couple years. I want to slowly do suspension and drivetrain mods now, while still saving for the forged and blown 383, that way I dont get that put in there, and then kill my clutch/rear/driveshaft and !any-trace-of-traction
Old Sep 10, 2004 | 02:55 PM
Would I really need valve seals? My car only has 14,XXX origional miles on it ... ?
Old Sep 10, 2004 | 03:06 PM
LWillmann's Avatar
Valve seals are pretty cheap if I remember, and they certainly won't hurt.
Old Sep 10, 2004 | 03:23 PM
94 CAMRO Z28's Avatar
For the money all that is going to cost you, why not just get the hotcam kit? Probably wouldn't cost that much more. Also, the spring compressor I believe you can rent for free at Autozone.
Aaron
Nov 18, 2023 07:21 PM
Cam's maro
Mar 24, 2015 08:09 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Collector Car
Jan 5, 2015 10:58 AM
