Misfire while cruising
Old Nov 21, 2021 | 12:00 PM
warriormpw's Avatar
I have a 1995 Z28 that only misfires while I'm cruising. It is not noticeable while idling or under load. Here is everything done to the car
280FXI cam, LT4 ported and polished heads, LT4 ported intake manifold, port matched 58mm TB, 1.6 roller rockers, LS7 style lifters, hardened push rods, 42lb/hr injectors, 2800 stall, 3.42 gears, 13 vane pump, RPM trans clutch kit.
Last weekend I replaced Opti spark, fuel filter, both 02 sensors, and spark plugs. The opti spark fixed my original issue of the car misfiring and back firing all the time, but now it still misfires when I'm cruising.
Old Nov 21, 2021 | 08:03 PM
mrmint69's Avatar
Re: Misfire while cruising
Have you had it tuned for the mods? Do you get any codes when you scan it?
mikemassi
May 8, 2013 10:49 AM
Birdman7389
Sep 20, 2005 12:28 AM
chrisbz28ss
Apr 7, 2004 03:28 PM
Dave Feerst
Aug 26, 2003 08:08 PM
93z28vig
May 30, 2003 04:28 PM
