misfire, optispark?
Old Feb 25, 2004 | 09:42 PM
kwbr's Avatar
Angry misfire, optispark?
first time user so please bear with me. i have a 97 1-le 6-spd thought i was having vibration problems. in neutral @ 1800-2000 there seems to be a vibration, also around 3000 but it gets worse coming down thru rpms like around 2800. you can have someone hold rpms in these ranges and watch the engine shake at the above mentined rpms. it is rpm related, it does the same in neutral, cltch in or thru the gears running. car runs strong, ive changed plugs and wires , checked balancer, changed clutch, pilot bearing, checked flywheel bolts, checked motor mounts, tranny mount, exhuast hangers, ran car without belt to eleminate accessories. can the optispark do this?thanx for any input
Old Feb 25, 2004 | 10:18 PM
Robs97Z28's Avatar
damn...I guess it could, but I would think that the ecm would be throwing a code(misfire code). possibly a P0300.
Old Feb 25, 2004 | 10:38 PM
kwbr's Avatar
thanx for your input, anyone else ? any other ideas what it might be, i'm kinda grasping at straws at this point
Old Mar 29, 2004 | 11:26 PM
jayman117's Avatar
I'm having the same problem you're having, except I just put in a new opti plugs and wires, so i'm scratching my head on this one, can't seem to pinpoint it
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
