misfire, next step?
Old Oct 19, 2013 | 08:30 AM
jnw86's Avatar
misfire, next step?
I just purchased my first LT1 car. Its a 94 Z28, which I got for a song. It had an unknown coolant leak, a bad misfire, and a ses light. I fixed a bad heater hose to stop the coolant, at which time I noticed the coolant temp sensor was busted and the plug was missing from the wire. After a new sensor and pigtail, the car runs a lot better and the ses light is gone. It starts and runs fine, but has a noticable miss at idle. I can gradually rev the engine and it will take rpm, but you can feel the miss. If I crack the throttle around 2000rpms, it will take revs... albeit rough. If I crack rd he throttle hard off idle, it stumbles and I get a bad spark knock. Should I assume the coolant leak ruined the opti, or assume that running in open loop fouled the plugs? Will be q nice car once I figure this out.
Old Oct 19, 2013 | 09:17 AM
Twenty8Z's Avatar
Re: misfire, next step?
If you haven't changed the plugs and wires yet, I would check them out next and see what you got.
Old Oct 21, 2013 | 08:25 PM
jnw86's Avatar
I'm really starting to suspect the Opti. It got hosed when the heater hose ruptured. Since I replaced the CTS, the car starts and idles great when cold, but backfires and misfires really bad when it warms up.
Old Oct 21, 2013 | 08:37 PM
moparman's Avatar
It should be scanned, as there are some things that don't turn the SES on.
Old Oct 21, 2013 | 09:15 PM
parkers Z28's Avatar
I would think if was the opti it would do this at all times ? since it does it best at operating temperature I would look at the I.C.M ???
replacing the plugs and wires are a pain in the a** but if you plain on replacing the opti
you should replace the plugs and wires just to eliminate that being the issue "I.M.O"
Old Oct 21, 2013 | 11:27 PM
jnw86's Avatar
The more I run the car, the better it is at idle. That would make me think plugs, except for the fact that it acts so bad once it warms up. I suppose I'm just going to have to start at the plugs and work my way back through the ignition system. Will low fuel pressure get a lean backfire in these engines?
Old Oct 28, 2013 | 09:39 PM
jnw86's Avatar
It was a bad ICM
Old Oct 29, 2013 | 04:01 PM
Thanks for posting what fixed you problem !!!
CamaroZ28.com has been a great learning experience for me
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
Bxlt1
Sep 17, 2015 08:31 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
