Milodon Windage Tray WONT FIT
Old Jun 17, 2005 | 09:51 AM
xxsaint69x's Avatar
Milodon Windage Diamond stripper part #32250 wont freaking fit with my stock pan. I have no problems with the rear but for some reason the tray wont clear near the front of the pan!?!? I already cut some of the sides to clear the 4bolt mains and it helped a little bit but thats about it. Any ideas what to do?
Old Jun 17, 2005 | 10:07 AM
Mystic97Z's Avatar
Re: Milodon Windage Tray WONT FIT
damn, i'm not sure about the part # for the miloiden trey i used. but the pan i used i'm not 100% sure came off an f body, it was a little different that the one that came off my car.. but mine went right in, it was snug but it worked.
Old Jun 17, 2005 | 10:25 AM
xxsaint69x's Avatar
i kinda got it to fit....REALLY TIGHT....here is another problem. how am i suppose to get to the nutts on the other side of the tray to tighten them?! Its so damn right i cant get anytihng in there.....
Old Jun 17, 2005 | 10:42 AM
Mystic97Z's Avatar
well ur gonna have to!! there is no other choice.
ya know how u put 2 nuts together on a stud and loosen one and tighten the other towards each other to tighten them up...u could do that for all the under side nuts, get them all tight, then put the trey on, then do the top..
but you will have to get 1 more nut for each stud,,if u do that i'd locktight the **** out of them, i don't know if i'd trust that personally.. why can't you put the bottom nut all the way to the bottom of the stud up against the main cap nut?
Old Jun 17, 2005 | 10:55 AM
xxsaint69x's Avatar
Would the tray bottom out on the nut that is resting on top of the main cap nut?
I am not sayin nut anymore!
Old Jun 17, 2005 | 11:51 AM
xxsaint69x's Avatar
blah i got it.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
adam85
Parts Wanted
Jan 1, 2015 02:24 PM
ddr698
Dec 31, 2014 09:16 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
