mild build lt1 boost reccomendations
Old Jul 7, 2019 | 10:40 PM
mutt355's Avatar
Hi all as the title states I’m looking for advice as to what boost I should make my max, bearing in mind the 2 bolt mains. I have finished the fabrication of all the turbo piping now just need to do final assembly
Parts I have are as follows
2 bolt lt1
arp main studs
stock crank
scat 5.7 h beam rods
wiseco forged -15cc pistons
cometic MLS head gasket
stock heads ported intake and exhaust unknown flow
ARP Head studs
scorpion 1.6 RR
lunati 282/290, Lift .535/.550 cam and springs,
full dry sump
Msd 7al-3 plus
msd distributor
single plane manifold
blow through efi
e85 fuel
9.1 compression
twin gt3582 turbos air to air intercooled
I know it’s not an ideal parts list for a build but I have managed to pickup almost everything from other people’s unfinished builds or leftovers, the only thing I had to buy from a retailer was the head gaskets and the studs. I will do head s and a more suitable cam one day when I can afford it
thanks
Old Jul 10, 2019 | 12:01 PM
David94TA's Avatar
Re: mild build lt1 boost reccomendations
There is a sticky note in the "Forced Induction" section called "Forced Induction and the LT1". It is an old thread but has some good basics that you might want to look over.
ramair96ws6
Sep 30, 2009 02:17 PM
-vellu
Jan 23, 2007 09:05 PM
swasenko
Mar 25, 2006 03:49 AM
swasenko
Aug 26, 2005 06:45 PM
swasenko
Jul 13, 2005 02:04 PM
