MIL Flashing
Old Nov 28, 2004 | 06:26 PM
JaWdRoPn's Avatar
MIL Flashing
My MIL is flashing at all times, all gears, all speeds. The engine misfires very bad, I recently replaced the connector my MAF sensor, both check ok! The scanner reads EGR, EVAP, and AIR pump malfunctions. What should I do as far as testing these? Which is most likely the problem? Thanks
Old Nov 28, 2004 | 06:42 PM
Re: MIL Flashing
Get the codes from your computer. The light is trying to tell you to check it.
Old Nov 28, 2004 | 06:45 PM
JaWdRoPn's Avatar
Re: MIL Flashing
I got the following codes:
P0101
P0300
P0400
P0441
I replaced the connector to the MAF, all ok now!
Old Nov 28, 2004 | 09:46 PM
meengreen 94z's Avatar
Re: MIL Flashing
It appears you've found the problem but...
A flashing MIL means a misfire(as you've realized)
Im not sure if GM OBD1 codes use the same pattern, but in OBD2:
100 codes mean a fuel related code
300 is a misfire code, 0 would be for unknown(a 301 would for cylinder 1, and so on)
and 4 is emissions related
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
4586
Aug 24, 2015 11:04 PM
4586
Aug 18, 2015 07:08 AM
whitehooptie
Jul 22, 2015 10:25 PM
