Might buy used SLP headers, need advice
Old Sep 13, 2004 | 08:02 PM
AnniversaryZ28's Avatar
I think i have found a good deal on some used slp headers. The fellow selling them says they are from his dual cat 96 ss.
My 97 is dual cat, so i assume they should fit. They are emmissions style headers(which i need)
My real question is about the y-pipe. I am told my stock y-pipe will work. Is this correct. Are the headers worth it useing my stock y-pipe?
THey are not coated, but stainless steal, i assume they should last right?
Old Sep 13, 2004 | 08:20 PM
Josh-'04 GTO's Avatar
Re: Might buy used SLP headers, need advice
Yep, they fit the stock Y pipe. You should get them coated, as they throw off a lot of heat into the engine compartment. I had them on my last bird and they were about as good as you can get and still be emissions compliant.
Old Sep 14, 2004 | 12:16 AM
bdc95ta's Avatar
I had some too. The coating doesn't seem to last very long though. I've never tried other coatings though so... Go with a jet hot coating I think those will last longer. They quoted me $143 bucks roughly awhile back. Not to bad. hth
-b
Old Sep 14, 2004 | 07:55 PM
2cub49's Avatar
Ya they work pretty good especially with a Random dual cat ypipe.
My current TPiS Longtubes setup makes only a little more power.
Old Sep 14, 2004 | 07:56 PM
AxeGrinder30thZ's Avatar
I got some coated by Jet-Hot. I eventually plan to step up to Longtube headers from Hooker, but if you have emissions, and have to get shorties, I highly recommend them. I could tell a pretty good difference.
ScottZ
Mar 3, 2004 01:34 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
