In the middle of t56 swap, have some questions
Old May 12, 2004 | 04:02 PM
joefreeland's Avatar
Im in the middle of putting the t56 swap. What do I do with the two wire connector that went to the coil on the shifter? All of the wire on the automatic shifter harness match whats on Alex's page except for the two 12ga wire, one is purpe and the other is yellow.
I also have one connector that is not hooked up under the steering column, it has four wires, black,blue,grey, and yellow.
I posted this in the drivetrain forum but thought I would get more responses here.
thanks
Brad
Old May 12, 2004 | 05:48 PM
961le's Avatar
12 guage wires are the ones used for the clutch start switch . just lengthen the wires and route them to the switch. the other wires i do not know about. all i had to do under the dash was get a jumper harness for the cruise control. alex page was informative but rather confusing.... i just ended up studying my manual and had no issues.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
HectorM52
Jan 31, 2015 07:29 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
nballisru
Dec 14, 2014 05:01 PM
