In the middle of optispark swap and have a question?
Old Mar 22, 2003 | 12:51 PM
ninjatertl's Avatar
From: In the Sewer with the Splinter & the other turtles
How the hell to you get the damn thing on? Im trying to align it with the dowl that is on the timing cover and the little notch that is on the optispark, but cant seem to get it flush. any tricks on doing it??
plus i am trying to change my coil and the bolt that has the eltectrical connection to it doenst seem to want to come off? what could i do there?
Old Mar 22, 2003 | 01:22 PM
phancom's Avatar
i just had lots of fun doin the opti also.
i took the left fan off and was able to stick my head up there to see where the notch was rotated to on the block. give it a try.
try to keep moving it little by little and turning the opti when you try to slide it back on.
Old Mar 22, 2003 | 01:27 PM
RamAir95TA's Avatar
If you have alot of trouble, you can try to mark the location on the cloverleaf and the timing cover and eye it up the best you can. It isn't easy, and will require some patience. Eventually, you'll get it on.
And are you talking about the two bolts securing the coil to the head? They should be relatively easy to remove. Try some PB and a breaker bar if you can't get them out.
Old Mar 22, 2003 | 01:40 PM
ninjatertl's Avatar
Ok i think i got it, but is it supposed to wiggle alot before it is bolted on? just want to check and make sure it is aligned correctly
Old Mar 22, 2003 | 01:45 PM
RamAir95TA's Avatar
NO!
It needs to be fully seated against the block before it's bolted in. You'll know when it's ready to be bolted down.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
