mid vs long tube headers
Old Mar 8, 2009 | 01:44 PM
  #16
canuck94z28's Avatar
Originally Posted by Travis68
I am looking at a set of MAC mid headers and was wondering how much HP I would give up as opposed to a set of say, pacesetter long tube headers? Also, how much easier are the mids to put on than the long tubes?
Thanks,
Travis
You,ll notice that my 60ft. stayed same after the Macs but picked up power in e.t/mph so IMO you might lose some low end tq w/longtubes.Also,some info. about your car would help members give recommendations.
Old Mar 8, 2009 | 10:39 PM
  #17
Travis68's Avatar
the car is a 95 t/a with an M6. The only mods I have right now and a CAI and a flowmaster, but I am getting ready to change the exhaust to an SLP 3 inch catback with a cutout.
Old Mar 9, 2009 | 06:49 AM
  #18
wrd1972's Avatar
Definitive proof LT's are better than Mid-tubes
Red = previous setup with mid-tube headers & 30# injectors
Blue = current setp with LPP long tube headers & 37# injectors
Old Mar 9, 2009 | 08:44 AM
  #19
95mysticta's Avatar
Nice dyno graph... it is no brainer that lts would outflow mids. Bigger primarys and a straighter flow out back. I still think that the AS&Ms or RK Sports will put down some pretty good numbers with the 1 3/4 primary in the mid style header. Ill know this year in the spring when i get them on to find out how much they net me.
Old Mar 9, 2009 | 09:25 AM
  #20
wrd1972's Avatar
For the record, the mid tube headers shown in my graph above were AS&M. IMHO, its LT's or nothing unless ground clearance or emmisions are an issue.
Old Mar 9, 2009 | 10:07 AM
  #21
96capricemgr's Avatar
Those swearing long tubes are the only way to go.
Are you willing to say my car would gain a meaningful amount with the longtubes?
Going to be another month before I know for sure. Just got 6-7" snow yesterday, tracks wont be open for awhile.
Old Mar 10, 2009 | 12:54 PM
  #22
95mysticta's Avatar
So you went from 374rwhp with the as&ms to 384rwhp with lts and bigger injectors. Bigger injectors would play some role but 10rwhp between the two of them insnt a huge difference really. If it was more like 10rwhp+ with just lt's then i could why you would be suprised from the huge difference. Both are good in there own ways im going to try out my as&ms for the year and if i happen to run across a good deals on lt's when i get rdy to drop my new motor in then why not.
Old Mar 10, 2009 | 12:57 PM
  #23
wrd1972's Avatar
Yes. Now look at all that new found low end torque. Believe me that torque gets things moving much quicker at lower RPM's.
The injectors are giving me nothing. I went larger to get the duty cycles a bit more on the desirable side. For full disclosure I wanted to mention the injectors and that the current cam has .030" less lift but the same durations. So I may have lost a very small bit there.
Old Mar 10, 2009 | 09:20 PM
  #24
lt1-xjs's Avatar
[QUOTE=95mysticta;5872148]So you went from 374rwhp with the as&ms to 384rwhp with lts and bigger injectors. Bigger injectors would play some role but 10rwhp between the two of them insnt a huge difference really. If it was more like 10rwhp+ with just lt's then i could why you would be suprised from the huge difference. Both are good in there own ways im going to try out my as&ms for the year and if i happen to run across a good deals on lt's when i get rdy to drop my new motor in then why not.
The injectors played role and tuning was involved, I'm skeptical.
Old Mar 10, 2009 | 09:29 PM
  #25
wrd1972's Avatar
[QUOTE=lt1-xjs;5872710]
Both runs were on a fully optimized tune. Injectors dont make horsepower unless they cant provide the right amount of fuel. AGAIN, the larger injectors work at a 80% DC where the 30# injectors were a tick over 90%. Both will deliver the correct amount of fuel. What you see in the graph is all headers.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Mar 23, 2015 08:06 AM
4586
Mar 18, 2015 06:31 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
