mezzier waterpump install?
Old Feb 4, 2004 | 02:47 AM
Zerosheaven's Avatar
anyone have any guids or directions on how to install a electic waterpump?? thanks
Old Feb 4, 2004 | 06:20 AM
johnny o's Avatar
http://www.projecttransam.com/projects9.asp
Old Feb 4, 2004 | 06:47 AM
Zepher's Avatar
I'd recommend using a relay and power the pump directly from the battery using the ignition to activate the relay.
Old Feb 4, 2004 | 02:25 PM
cool, thanks
but what do i do about the waterpump drive on the block of the engine??? do i remove it??seal it up???cut it?? or what?
Old Feb 4, 2004 | 02:47 PM
Mtrhds94Z's Avatar
If you want, you can 'leave it' alone actually...
Old Feb 4, 2004 | 03:17 PM
ok, i got the coyles double roller timing chain set and the chain was rubbing against the sprocket on the waterpump drive. so i removed it, do i need to clog the hole up or can i just leave it open?? thanks
Old Feb 4, 2004 | 08:13 PM
Zepher's Avatar
The hole that is in the block can be left alone, just make sure that you cover the hole in the timing cover.
Old Feb 4, 2004 | 08:49 PM
jonaddis84's Avatar
Haha, yeah you can pay a shop $30 to TIG weld that hole shut...****ers...just did it for free in class today, less than 1-min, but got charged $25 by a shop to plug the CPS hole!
Might as well take out the drive sprocket.
Old Feb 4, 2004 | 08:53 PM
Transamdriver's Avatar
The Mezirie should have come with a brass freeze plug for the pump housing and you can use a combination of washers, bolt, nut, and RTV to seal up the timing cover.
I have lost the link, but hopefully someone knows what I am talking about. You can kinda see it in this pic of my engine: http://www.auburn.edu/~doddjom/naws1.jpg
Nov 18, 2023 07:21 PM
Sergio
Jan 27, 2016 04:27 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Wilson
Jul 21, 2002 05:08 PM
