Meziere Pump Relay Questions
Old Nov 4, 2005 | 07:06 PM
Dfetter84's Avatar
Ok........
My pump definetly works...
I rigged it to the constant power source at the passanger strut tower.....
if you look at the relay under side like below pretend these numbers are the pongs
ok 5 should be left alone.....right
i have the blue wire from the pump going to relay prong #2
the black wire goes to ground from the pump
prong # 1 goes to the relay box to a 15A fuse for A/C something so that when i key-it forward pump=ON
and #4 = ground to relay
i know somethings wrong
i had this working before but i put a new engine in and am trying to figure this out again
Someone school me please....
Old Nov 4, 2005 | 07:37 PM
DDZ/28's Avatar
Re: Meziere Pump Relay Questions
Where's your fused power source? (which pin)
Old Nov 4, 2005 | 07:52 PM
djlunchbox's Avatar
damn, i wish i had my truck here right now and i'd go out and tell ya what goes to what...
Old Nov 4, 2005 | 07:53 PM
Dfetter84's Avatar
which one
i have the fused link from the water pump and i have the 15A line that im using
Old Nov 4, 2005 | 07:54 PM
Dfetter84's Avatar
i hear ya man
i shoulda took pictures of my relay
i HATE electrical work
Old Nov 4, 2005 | 08:23 PM
Dfetter84's Avatar
ok i got it
Thanks to my boy Jeff @ PSI Performance Specialties IND
my boy knows his stuff
Central MD Extraodinaire
heres the answer
1 = ground
2 = Power to Water pump
3 = Power to fuse in fuse block
4 = Always HOT run it to strut tower on passenger side
5 = not used/ no connection externally
Got It Got It Good
Old Nov 4, 2005 | 10:45 PM
3gc's Avatar
3gc
I just wired up my Meziere pump today. I used the fuel pump jumper wire near the heater box to power my relay so it's only on when the fuel pump is on.
Old Nov 5, 2005 | 07:47 AM
Dfetter84's Avatar
Mine is similar like yours
when key is forward the pump will get power
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
MYT30TH
Jul 28, 2002 08:47 AM
