meziere EWP leaking?
bought it used. i dont think that has anything to do with it though.
there are 2 holes on it. one on top and one on bottom. someone told me they are weep holes.?
anyway it seems to be getting better. but every time i turn the car off it leaks coolant for a few seconds (30 secs). i jacked the car up and turned it on and off and it didnt leak. once i took it off the jack and did it it started leaking. i watched it come outta the WEEP hole. i really doubt that that hole is there for that reason. so y is coolant coming out of it? and it dont do it while the car is running. but only after i turn it off.
please help, all suggestions welcome
TIA
TIA
Re: meziere EWP leaking?
TIA
TIA
Unless you can confirm that coolant is leaking around where the Meziere bolts to the water pump in the front? There should be an o-ring/gasket between the water pump housing and the electric pump mounting plate.
from what i gathered from your response, is that u took it that my stock WP housing is leaking from a weep hole. if i understood that right, that is not what is leaking. a hole in the bottom of the meziere ewp.
this is kinda the hole i am speaking of, but the one that is leaking is on the bottom of it. exactly parallel. in the same spot. http://img.photobucket.com/albums/v6...zaro28/ewp.bmp
if it is still ?able where it is leaking from i will get a pic at work tomorrow.
