mezeire water pump
Old Apr 8, 2008 | 01:30 PM
jtarp's Avatar
mezeire water pump
Do i need to order a new housing when i order the pump, or do i just use the stock one?
Old Apr 8, 2008 | 01:34 PM
97HawkLT1's Avatar
You can uses the stock one. Here is a link to an install guide. http://www.projecttransam.com/projects9.asp
Old Apr 8, 2008 | 04:11 PM
lt1junkie's Avatar
Just FYI i just installed mine.. and you have to trim the fan shroud just a lil to get it to fit
Old Apr 8, 2008 | 08:39 PM
jtarp's Avatar
thanks for the input. the install guide helps alot. Thanks again
Old Apr 8, 2008 | 09:04 PM
caldercay's Avatar
As mentioned, use the stock. I attempted to hammer out the impeller
and bearings (no press in the garage), but gave up after 5+ minutes.
I took the water pump to a local auto shop (well equipped) and they
pressed it all out for $10.
The fan shroud will have to be trimmed slightly:
http://picasaweb.google.com/calder.c...45403260075506
I also suggest you get a relay, if you havent already. I have mine wired
so if the pump dies, a little buzzer under the dash will go off.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
