Metered ICM harness and got......
Old Dec 18, 2005 | 09:02 PM
djm_e22's Avatar
Ok my car takes either 10 minutes to die or will last up to an hour before it will die, and it can take up to 45 minutes before I can get it to start. I tested the ICM harness when the car would not start and am not getting the 1 to 4 volts. But of course I do get the correct voltage when the car does work. So what do you think this is that cause it to sometimes work but sometimes not. Thanks for any help.
Old Dec 18, 2005 | 09:17 PM
creed1062002's Avatar
Re: Metered ICM harness and got......
Mine car has also been doing that, if i leave my key on my fuel pump will reset and run for another 5 seconds. Sometimes it will click off then back on before the 5 seconds is up. The other day it ran for about 20 seconds straight.
Old Dec 20, 2005 | 06:29 PM
can the opti make it kill the power?
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
9
Sep 20, 2015 11:23 AM
tdigger9899
Sep 7, 2015 10:56 AM
