Mechanic trying to BS me.
Old Mar 29, 2006 | 06:38 PM
MENEGRANDE's Avatar
So I took the car to the mechanic, because it's backfiring big time. I currently don;t have a catalityc converter on the car, took it out about 1 month ago, after I took it out the car started having problems. So he tells me that he put a new cat and the car stop backfiring. Is this true? He is charging me 150.00 plus 75.00 for labor.
Not having a Cat will cause backfiring?
Thanks.
Old Mar 29, 2006 | 06:39 PM
MENEGRANDE's Avatar
Re: Mechanic trying to BS me.
By the way its a 1993 camaro lt1 with lt headers and a 3in flowmaster exhaust.
LastOfBreed's Avatar
Backfire? I don't believe so. It will pop and crackle though.
Old Mar 29, 2006 | 06:40 PM
MENEGRANDE's Avatar
a lot of popping. not flames or anything..
Old Mar 29, 2006 | 06:48 PM
96flame's Avatar
If you had exhaust leaks at the connections when you removed the cat then you may get some backfiring when you let off the throttle. If its sealed up then you should be fine without a cat.
Old Mar 29, 2006 | 06:50 PM
96superZ's Avatar
mine is a 96 with no cats and it snaps and crackles like a bowl of rice crispies, its fine dont let him touch it just leave it alone
Double aught
Oct 2, 2015 11:29 PM
Hal Fisher
Sep 30, 2015 09:03 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28newbie
Sep 9, 2015 10:26 AM
