McLeod Street Twin
Old Apr 27, 2003 | 04:20 AM
Fastbird93's Avatar
McLeod Street Twin
I just ordered one last week (smoked my clutch last thursday at the track), and have a couple of questions:
Does is come with the new high flow master cylinder? If not, where can I get one?
Does it come with a throwout bearing, and if not, where and which one should I get?
How have people found the most effective way to drive/launch on this clutch because I heard that it's an on/off clutch I.E. no slippage at all?
Thanks guys!
Old Apr 27, 2003 | 06:28 AM
IllusionalTA's Avatar
Wow... Good ?'s.. i can answer them all.. thankfully.. well first one.. yes it comes w/ the new upgraded slave.. Just the upper half.. you have to use your factory bottom half and braided hose.. Be careful when you open up the box.. their is a lil' o ring that you NEED... Dropped mine and spent 1/2 hour looking for it.. The clutch comes w/ a new throwout bearing as well.. And as far as driving it.. It by no means is a on/off clutch.. I think its the smoothest Hi Performance clutches ihave ever driven.. I have one.. and i absoulutely love it.. The pedal pressure is significantly harder than a stocker is so get ready for a leg workout... But not too bad at all.. Take up is smooth as a baby's butt but IT WILL break everything behind it.. i've been through 3 driveshaft's and a t56 so far.. don't dump this clutch on slick's.. let it out slowly.. it'll be nice to your driveline.. Good luck.. you made the right choice..
Old Apr 27, 2003 | 06:55 AM
Fastbird93's Avatar
Whew, thanks for the quick reply! I was totally under the impression that I needed to purchase separately the throwout bearing.
As for the "upgraded" slave cylinder, this is the one that's "high flow" to let the clutch engage/disengage faster right?
I don't plan to run slicks yet. I have a 10 bolt out back, and stock drive shaft too. Once I go carbon fiber driveshaft and 12 bolt, I'll probably to a tranny rebuild/upgrade before I really try to cut some low sixty's.
Thanks again!
Old Apr 27, 2003 | 08:50 AM
Super Slow '97's Avatar
What about a flywheel or will the stock one work fine? I know thunder racing has them listed w/ a flywheel is this necesary?
Old Apr 27, 2003 | 09:12 AM
Fastbird93's Avatar
I don't believe that they sell the kit without the flywheel. I've heard that it would chew right through the stocker.
Old Apr 27, 2003 | 10:17 AM
Black6SpdTA's Avatar
where did you get yours?
Old Apr 27, 2003 | 10:54 AM
Fastbird93's Avatar
Quick Time Performance, sorry but I don't know the web address right off hand. It was a great deal, but I'm not gonna mention prices because I don't believe they're a sponsor of the website.
Old Apr 27, 2003 | 11:34 AM
JSK333's Avatar
Unless they switched back, I thought they ditched the slave cylinder mod for their master cylinder. Make sure, because the slave mod is a REAL pain, and seems to eventually leak regardless.
It should come with a flywheel, that is thinner than stock, because of the increased thickness of two discs and a floater.
You should be able to drive it normally, clutch-wise. It will slip. But only with the clutch partially in--it won't slip when fully engaged, which is what we want.
Enjoy it, it's an awesome clutch!
G-BODYT56
Jan 14, 2022 11:14 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
Louey
Pacific
Sep 1, 2015 07:19 PM
