Max lift stock springs can handle?
Old Sep 14, 2004 | 10:27 AM
flusz28's Avatar
i have stock heads on my 94 z28 and i installed 1.6rr . crane golds - now how do i know what the max lift is for my stock springs?
Old Sep 14, 2004 | 11:14 AM
WS6T3RROR's Avatar
Re: Max lift stock springs can handle?
hate to say it but if you put 1.6 rockers in you probably need new springs right now. stock springs are pretty much maxed out with stock lift and you just threw about another .030 on top of it. if you dont have much money to spend put some lt4 springs on it for around 30 dollars, if you have the cash and you want something a little better but still cheap get some of combo's ex612 springs. also if you dont have one get an lt4 knock module so your motor doesnt get false knock and pull your timing back which would negate any gains from the rocker might even make less power with false knock. but i would highly recommend against using your stock springs with 1.6 rockers.
Old Sep 14, 2004 | 12:03 PM
teke184's Avatar
max lift is .525"
i beleive you can get away with stock springs on 1.6rr but you are VERY VERY close to the max lift...like .005" off....
ls6 springs work on the lt1 i think...those are .570" lift and are fairly inexpensive
Old Sep 14, 2004 | 09:21 PM
flusz28's Avatar
well i'm going to put the stock ones back on for now and this winter i will mess around with the other stuff. for new springs do i have to shim them? i just want to drive it with my supercharger i installed 1.6rr can wait... thanks guys
you live in the keys huh? family has a house in cudjoe key awesome area..
Old Sep 14, 2004 | 10:23 PM
flusz28's Avatar
found LS6 springs for $6bucks a piece. but i will wait till this winter to mess with that stuff.
Old Sep 15, 2004 | 01:30 AM
S8ER95Z's Avatar
Get the EX612s from combination motorsports http://www.cmotorsports.com/93-97-fb...ine-valvetrain
Good for .600 lift and fit right in place of the stockers. Plenty of spring for a cam later on only a little over a 100bucks for springs, retainers and locks then you can use your stock seats.
Old Sep 15, 2004 | 06:31 AM
Mtrhds94Z's Avatar
Stock springs max out at .490..
Stock 94 cam is:
1.5:.450 .460
1.6:.480 .491
LT4 Hotcam is:
1.5:.492 .492
1.6:.525 .525
Old Sep 15, 2004 | 10:40 AM
flusz28's Avatar
alright cool thanks for the help guys...
Cam's maro
Jan 30, 2015 09:21 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
