Max lift on LT4 Springs?
Old Jul 30, 2004 | 04:04 PM
RallyRed701/2's Avatar
I am interested in doing the Scorpion 1.7rr's soon and i was wondering if the LT4 springs would do the job. This would be on a stock cam, so i imagine the lift wouldnt be too bad. I think i worked it out and with the stock cam and the 1.7's the lift would be about: 506.6/520.2 . The only reason i plan on doing the rr's and not a cam is because i have such high milage. My plan was to do the rr's and just drive it like that till the thing goes, then rebuild something a bit better, throw heads/cam in it, and then id already have the rr's ... minus the new springs i would need. Thanks for any input.
Old Jul 30, 2004 | 04:09 PM
GREGG 97Z's Avatar
Re: Max lift on LT4 Springs?
The lift with the hotcam and 1.6 RR's is .525/.525 so I would think those springs should work ok with 1.7's and the stock cam as long as it doesnt exceed .525 lift.
Old Jul 30, 2004 | 05:33 PM
Does anyone know what the exact numbers would be with stock motor and the 1.7's from scorpion?
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
