Max bore size?
Old Feb 6, 2005 | 01:03 PM
swasenko's Avatar
Max bore size?
I was wondering what the max you could bore out a LT-1. I had mine bored out to a 383 stroker and then I dropped a new 12 bolt in the rear and took it up to Firestone to get it aligned. They smacked the oil pan against the hoist and killed my oil pressure and fried my motor. Now I'm wondering if I can take it out any more or if I have to get a new block. I want this to be able to hold up to a high hp supercharged application.
Thank you LT-1 guru's
Old Feb 6, 2005 | 01:12 PM
96camaroz28lt4's Avatar
Re: Max bore size?
4.060 so .060 and that's what I have.
Old Feb 6, 2005 | 01:32 PM
texasTA's Avatar
Re: Max bore size?
You can go as far as I have seen a .060 overbore, but not a lot of people here do that. It just makes the cylinder walls very thin. I wouldn't worry to much with a .040 bore. That is what I would suggest you to go with.
Old Feb 6, 2005 | 03:42 PM
ChrisUlrich's Avatar
Re: Max bore size?
.60 over with what size stroke? How many 427's have LT1's become?
Old Feb 6, 2005 | 04:00 PM
Re: Max bore size?
I have .060 with the stock stroke and it runs fine with hyperuratectic pistons and it has no heat problems and hasn't given me any problems. I did it for top end but I'd recommend .040
Old Feb 6, 2005 | 05:02 PM
chy20k1's Avatar
Re: Max bore size?
i hope thier paying for your motor, it was thier fault.........
Old Feb 12, 2005 | 11:10 AM
swasenko's Avatar
Re: Max bore size?
I'm in the middle of sueing them, so hopefully they'll have to pay for it. It sure is there fault, but they're denying it. It's already .030 over so I hope taking it out to .040 will clean it all up. I don't want to go to .060, I'm a litlle afraid of what might happen.
Thanks guys
Steve
brothaslide
Jan 9, 2016 12:11 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
colts0455
13
Aug 7, 2015 09:15 PM
