Map sensor volts and spark advance readings
Old Aug 22, 2003 | 06:16 PM
$hawn's Avatar
What are the map sensor volts supposed to be before starting and idle, mine are 4.66 before I start the car, and at idle it's 1.05-1.07. Spark advance is 2* before start, and at idle it's bounces between 23-25*. Also the IAC count when warm is 97 before the engine is started. Actually all these reading are when the engine is warm, do they sound kosher to you guys? Thanks
Old Aug 22, 2003 | 07:45 PM
Sounds pretty normal. You might want to read Fred's blurb on scanner readings.
Old Aug 22, 2003 | 09:10 PM
$hawn's Avatar
Yeah, I'v read Fred's scanner readings page, some of those it didnt really go into detail all the way, like with the 2* with the key in the on position, and the iac at 97 counts I was sure about either, everything else seems good.
Old Aug 22, 2003 | 09:32 PM
Some things are not really significant when the engine is not running.
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
Jazsun
Dec 29, 2014 12:14 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
