Manual cooling fan switch?
Old Jan 29, 2006 | 06:12 PM
danny525's Avatar
Question Manual cooling fan switch?
Want to be able to turn on my fans manually, i got one site from one guy on here, and it seems to be good, but want to look a bit more into it. Anyone got any goos sites or ideas on how to do this?
Old Jan 29, 2006 | 06:15 PM
MyShibbyZ28's Avatar
Re: Manual cooling fan switch?
My site, under how-to's. Site is in the sig. Yeah it's not the greatest walk through but it is something none the less. Hope it helps.
Old Jan 29, 2006 | 06:46 PM
danny525's Avatar
so is that blue wire in one of the connectors going into the pcm?
Old Jan 29, 2006 | 06:52 PM
Yes, the red wire is extra wire I used for the switch to the pcm. Did you see schoebox's site for the schematic? He has a picture showing which wires to snip.
Also, didn't you say you wanted to replace the temp sensor rather than make a switch?
Old Jan 29, 2006 | 07:58 PM
danny525's Avatar
ya i did, but after replacing it, there was the same problem, so i made a switch. But i made the connection at the point on the strut tower (its the only place i could see the wire with the H, so i made it there. But i dont know if thats the wires going into or out of the pcm, all i know is now i can turn on my fan,and it keeps my car cool, but it runs all the time and not just when the car running, and i think it caused my service engine soon light to come on. You ever get this problem?
Old Jan 29, 2006 | 08:06 PM
danny525's Avatar
okay, i looked at shoeboxes site and yes thats what i did, the only thing i did diffrent is i spliced it after the connector instead of before it. but thats what i did, so any idea why it wont shut off when i turn off my car or why my service light is nw on?
Old Jan 29, 2006 | 08:07 PM
No, the only problem I had was attaching the ground to a positive so it ran when the car was in "on" but not running. When I switched it to negative it worked like it should. I can leave my switch on and turn the car off, and the fans will turn off too. You need to attach the wires before the relay, otherwise you might be pulling it straight from the fan and running way to much current, which can heat the wire up and melt it.
Old Jan 29, 2006 | 08:49 PM
danny525's Avatar
ohhhh so is the party that shows all the letters the relay?
Old Jan 29, 2006 | 08:58 PM
I will get a picture later of exactly where to snip. It's in between the PCM and the "thing" with letters on it.
Old Jan 29, 2006 | 09:19 PM
danny525's Avatar
Thanks i think i know what your talking about now, hopefully when i move it before the "thing" i still dont know what you would call it lol, i will get it to turn on with the car, as well as it to turn off my service engine light. Do you know off hand if you fix the problem that turns on the service engine light, will it turn off, or will i need to have it turned off?
Old Jan 29, 2006 | 09:51 PM
If I remember right the "thing" is a relay. I never had a check engine light problem. But I also had it in the right spot to start with. Your fans not being hooked up right through the relay might be tripping the SES light. Like I said, I will get a good picture tomorrow of where and how I spliced the wire.
Old Jan 30, 2006 | 11:31 AM
Old Jan 30, 2006 | 11:37 AM
In the first picture, notice the big collection of wires? Closest to my fingers. Those run into the relay on the side of the PCM, going into it from the top. It comes out the bottom and there is a blue wire, lettered "H". That is the high speed fan wire. I used that one and only that one since it cools the car off plenty. I spliced after the relay, so on the downside of it in that first picture. Then the wires run off somewhere else that doesn't matter right now. I snipped that blue wire in half, stuck a splice-like wire connector in there with the wire for the fan switch. Then took the other wire coming from the fan switch and hooked it to the ground. Doesn't matter where you put the ground really, as long as it is to a negative.
Also before I forget, did you cut the right wire on the right relay? There is a C100 and C105, you want to find the C100 and the letter "H".
Old Jan 30, 2006 | 12:54 PM
danny525's Avatar
okay i put the splice in before the relay, and yes its too the right relay, and the right wire, but my light is still on so i guess im gonna have to take it in. Im making a 1200 mile drive back to canada from california so i better just get it fixed. Thanks for the help-danny
Old Jan 30, 2006 | 04:30 PM
If followed, the wiring diagrams on my site requires no snipping at all and will not set an SES afterward. Not everyone does a fan swith the same way and with the same results.
