Manley valves same v. stem seals as stock?
Old Jan 13, 2004 | 01:22 PM
FireAm94's Avatar
I have some manley 2.00 1.56 valves that will be installed in my new heads. Do they take the same valve stem seals as the stockers?
Thanx
Joe
Old Jan 13, 2004 | 02:04 PM
Don 97 SS's Avatar
Most likely they will be the same, but you need to check the stem diameter to ensure a proper fit. I'm using oem design seals on my 2" valves. (Victor Reinz valve stem seals Car Quest P/N B45796 $19/set)
BTW, I used to live in Decatur.
Old Jan 13, 2004 | 02:49 PM
Grease's Avatar
I have Manley 2.00/1.56 valves in my heads and I use stock valve stem seals. So to answer your question, yes, they will work fine.
Old Jan 13, 2004 | 04:31 PM
FireAm94's Avatar
Thanx for the responses guys! Aren't they the same as a standard 350?
Joe
Old Jan 14, 2004 | 07:03 AM
Don 97 SS's Avatar
Joe
They may or may not be. That is why you should check. If you gave Manley P/N it would be easy to check to be certain. But there are many products on the market and frequently when using a high performance valves, the stem dia. may be reduced for increased air flow. For example, all BBC engine come from the factory with valve stems that are 3/8", but many aftermarket valves, particularly stainless steel, are 11/32". Close but not the same.
Old Jan 14, 2004 | 09:32 AM
FireAm94's Avatar
That will work...I was just curious as to the standard 350 thing. Yeah....that part number will save the person at carquest who would have given me the wrong part # hehe. Thanx again.
Joe
Old Jan 15, 2004 | 07:02 PM
arnie's Avatar
If you are referring to stem dia., then, for about the last 49 years, (any) sbc has been the same.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Jazsun
Dec 29, 2014 12:14 PM
