mallory 685 harness wires not same color
Old Jan 8, 2008 | 10:48 PM
starbucks's Avatar
So i bought the mallory 685 and the harness to hook it up to the coil (harness part no# is 29068) but the mallory harness wire are not the same as the wires coming out of the box. the wire on the harness are one green one red one white and one pink. Coming out of the box i have one green on yellow one black and one red. so can anybody help me hook this thing up?
Old Jan 9, 2008 | 09:50 AM
starbucks's Avatar
any body?
Old Jan 9, 2008 | 09:56 AM
If the harness is the correct one to adapt the unit, then it should not matter what color the wires are.
Old Jan 9, 2008 | 10:14 AM
FryedClutch's Avatar
if you do a little searching on here there is a conversion so you can use the instructions from a msd box to make sure you get the wires correct
once you get it all hooked up your def gonna love it though so many great features for the price
and remember if your gonna use the window switch the purple wire grounds the circuit
Old Jan 9, 2008 | 11:00 AM
https://www.camaroz28.com/forums/sho...17&postcount=7
here is the post with the msd to mallory conversion colors
then just go to the msd website look up a 6al and page through the instructions and make sure you have all the colors going to the correct places
its a roundabout way but it will get ya there
Old Jan 9, 2008 | 06:55 PM
starbucks's Avatar
Here's the thing though im not going from an msd harness to an mallory box im goin from a mallory box to a mallory harness
Old Jan 9, 2008 | 08:12 PM
right but with that info it should help you trace down the wires to make sure your putting everythin in the right place
Old Jan 10, 2008 | 02:21 PM
starbucks's Avatar
This is getting crazzy i called up mallory today and asked them why there are diffrent colored wire and whitch one is what and they proceded to tell that the mallory 685 will not work on an lt1. then i told the guy it has an external coil and then he told me that i bought the wrong harness and that they dont sell one for an lt1. I then told him that it is all hooked up and all i need to know is what does the white and pink goto on the box side of the wiring needless to say he could not help me.
Old May 9, 2008 | 10:45 PM
pyro719's Avatar
I am having the same issue as the thread starter I have the 685 and the mallory harness but the wire colors dont match, I need help wiring this thing up.
Old May 10, 2008 | 07:52 AM
94v6a4's Avatar
Connecting MSD harness to Mallory Harness
(MSD)Red to (MALLORY)Red
(MSD)Black to (MALLORY)Black
(MSD)White to (MALLORY)Green
(MSD)Orange to (MALLORY)Yellow
good luck
Old May 10, 2008 | 08:56 AM
pyro719's Avatar
No I have the mallory adapter plug as well as the mallory 865 hifire VI. The wire coming out of thr mallory are, red,black,yellow,green for one plug. Another plug has black,red,then I have a small green wire and a small black wire. On my adapter harness the wires are red,green,pink and white.
Old May 10, 2008 | 11:27 AM
pyro719's Avatar
Anybody? I am kicking myself in the *** right now for not buying the msd harness instead.
Old May 10, 2008 | 12:08 PM
MichiganSkip's Avatar
What's the part number of the Mallory harness you have?
Old May 10, 2008 | 12:15 PM
This the one?
http://www.malloryperformance.com/pdf/29068.pdf
Old May 10, 2008 | 12:19 PM
pyro719's Avatar
yes that is the harness I have.
