Maintenance Questions
Old Nov 13, 2003 | 02:23 AM
Ace_437's Avatar
I've put my 93Z in the garage for winter storage and have been thinking about doing some routine maintenance on it. She's only got around 35,XXX miles on her. I'm going to do the throttle body bypass, but what else should I try to do? I'm pretty sure everything is original/stock down to the battery. I did put the SLP CAI on a year or so ago. I was thinking about sparkplugs, but it seems like a major PITA! I doubt the tranny fluid has ever been changed, how hard is that to do?
Old Nov 13, 2003 | 02:44 AM
Compstall's Avatar
Spark plugs = they ARE a PITA! You can get to all of them once you pull the alternator and starter. If your arms are skinny enough you can do the #8 plug WITHOUT pulling the starter. You can get 3 of the driver's side from the top, the last one from underneath.
Old Nov 13, 2003 | 02:50 AM
Van5150's Avatar
Those original spark plugs are rated for 100,000 miles usage, at 45K on my car the dealer refused to change them, really.(now I know why, they suck to change)
Antifreeze and clean off the three little resistors on the Mass Airflow Sensor, dont touch them or you will blow up, use electrical contact cleaner on them.
Old Nov 13, 2003 | 03:45 AM
Heatmaker's Avatar
Advanced Member
Old Nov 13, 2003 | 09:50 AM
Ace_437's Avatar
No MAF on my car to clean.
NewsBot
Feb 26, 2015 02:10 PM
NewsBot
Jan 21, 2015 06:10 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
nophix
Nov 30, 2014 10:26 PM
