Maintenance Intervals
Old Jul 19, 2008 | 02:33 AM
MarcR94v6's Avatar
On the LT1, when are the following supposed to be changed (ie: every xxxx amount of miles)?
-Spark Plugs
-Plug Wires
-Distributor Cap and Rotor
-Transmission fluid and filter for A4 and M5/M6
-Fuel Filter
Add anything else you can think of that I have not listed, maybe it can be stickied or at the least be made a good search reference, as I didn't find any threads like this when I searched.
Old Jul 19, 2008 | 05:41 AM
MARKTHOMASBRAND's Avatar
According to the handbook,under "normal" driving conditions (shedule II intervals) :
Oil and filter change :Every 7,500 miles or every 12 months,whichever occurs first.
Automatic transmission service (normal conditions) :Every 100,000 miles.
Spark plug replacement :Every 100,000 miles.
Engine accessory drive belt inspection,cooling system service,spark plug wire inspection,air filter replacement,fuel tank,cap and lines inspection :All every 30,000 miles.
There is also a maintenance shedule I, which if for extreme conditions ie:Most trips are less than 5 to 10 miles,most trips include extensive idling,most trips are through dusty areas,you frequently tow a trailer etc,etc.
The intervals are obvioUsly much sooner under these conditions.
It doesn't actually mention the fuel filter,I usually change mine once a year,although I only cover 5,000 miles a year.Distributor cap and rotor aren't mentioned either.
Regards,Mark .
Old Jul 19, 2008 | 05:52 AM
NukeFPE's Avatar
Some other things to consider:
- Flush & change brake fluid at 2 years or when you change brake pads
- Change power steering fluid at 2 years
- Change rear end 80W90 at 30, 000 mile intervals
- Clean IAC & MAF at 10,000 mile intervals or when you change air filter
This has worked well for me w/ 1994 Z/28 A4 182,XXX miles & running strong
Old Jul 19, 2008 | 06:50 AM
96capricemgr's Avatar
I am very glad to see someone talking about a cap and rotor as periodic maintenance, far too often overlooked and then people curse the design when it fails. Honestly the interval on that could probably be 75-100K depending on use. I know I changed an original on one of my cars at 96K because I bought into the internet stupidity about how bad the opti was, assumed it was the problem, later found it had a dead injectors, at 96K the opti was good yet.
Plugs and wires is going to be be very dependant on what you use. A set of basic NGK or Autolite plugs and 20K is going to be plenty, stock 96-7 double platinums 80K and I bet they still work.This is a construction difference not a quality one.
Wires will depend on quality you buy and how well you route them.
Old Jul 19, 2008 | 08:05 AM
-Spark Plugs
-Plug Wires
-Fuel Filter
As already listed, your owner's manual has a service schedule for most items. Anything else can be asked about.
jbert55
Oct 31, 2015 03:52 PM
Godamnilovemy79
Sep 3, 2015 03:40 PM
jbert55
Aug 3, 2015 05:49 PM
ecthemc
Jun 19, 2015 06:54 AM
