Magnesium centerbolt valve covers.
Old Jan 20, 2010 | 10:08 PM
Eric85's Avatar
So i bought a set of these because a buddy of mine said they fit on his lt1 with his comp pro mags 1.6 rockers and then did a search on here for them and found one thread from 04 that says only 1.5 rockers will work but my buddy says he has them on his no problems. Anyone else use these since then?
Old Jan 20, 2010 | 10:25 PM
Bersaglieri's Avatar
If the stock ones fit with minor alterations then aftermarket ones better fit. Got any pictures?
-Dustin-
Old Jan 21, 2010 | 09:52 PM
Eric85's Avatar
well they are stock. They came on the TPI's and also the first year corvette with the lt1. Looks like im going to have to cut out the drip tabs or take a set of pliers to them. Anyone got a picture of what to do with the pliers?
Old Jan 23, 2010 | 09:48 AM
Stl94LT1's Avatar
I've seen pics where someone tried to break the drip tabs off with pliers and cracked the valve cover. I cut mine off with a dremel.
Old Jan 23, 2010 | 05:39 PM
Eric85's Avatar
is that all you had to do was cut them off to fit the rockers?
Old Jan 24, 2010 | 06:40 AM
vetteoz's Avatar
Usually have to pinch the breather baffles in with pliers for clearance also.In extreme cases with wide body rockers , TPI guys have narrowed the hold down bolt posts as well
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
