MAFT...yes or no??
Old Aug 3, 2003 | 02:56 PM
vampyr95Z's Avatar
MAFT...yes or no??
Just bought a used maft.Does anyone else use it?How hard was the install?Are there any write-ups on the install of one.I have pcmforless tuning but still running rich.
Do you need lt1 edit or can you tune with dyno and A/F?
Old Aug 4, 2003 | 04:21 PM
vampyr95Z's Avatar
Anyone????????
Old Aug 4, 2003 | 04:28 PM
turbo_Z's Avatar
the MAFT will only adjust the output frequencies of the MAF to a value either rich or lean depending on which way you turn the ****. now without a scanner you wont really know which way to adjust the **** so you are basically guessing and if you guess the wrong way then there is a chance the car could go lean at WOT. if i were you id invest in a decent scanning utility for a laptop or a scanmaster before you go turning *****.
Old Aug 4, 2003 | 05:33 PM
vampyr95Z's Avatar
I will not be adjusting it,will have it done on the dyno!!
