maf worth buying?
Old Jan 28, 2005 | 12:45 AM
Huntr1117's Avatar
maf worth buying?
For $200, is a granatelli maf worth buying? Does it really make a difference compared to stock. I'm asking this on behalf on my brother who has a 97 WS6 with exhaust, and an airfoil. Just curious anyone running with this Maf is it a noticable difference or not?
Old Jan 28, 2005 | 02:10 AM
GreenDemon's Avatar
Re: maf worth buying?
Tell him an intake will do a better job of freeing up some power. Or better yet, put that 200 towards some headers. Once you have enough horsepower that the MAF becomes a restriction, usually it just gets chucked and the MAP sensor gets relied on anyway.
Old Jan 28, 2005 | 02:56 AM
97WS6SCharged's Avatar
I forget where the MAF maxes, I want to say around 475 gps. Unless you're doing a hefty forced induction motor, the MAF really isn't a big restriction.
Old Jan 28, 2005 | 07:50 AM
Most people are disappointed with aftermarket MAFs. I would consider it a poor investment for your brother.
Old Jan 28, 2005 | 09:31 AM
Huntr1117's Avatar
Any idea of what kind of Hp gains he can expect from a Maf?
Old Jan 28, 2005 | 09:35 AM
NOMAD's Avatar
Nothing. Get a CAI. I've got my old one for sale for $100. Or buy a set of headers. Too many good power gains to be had bsides a granatelli.
-Shannon
Old Jan 28, 2005 | 09:43 AM
Huntr1117's Avatar
He already has Ramair, so a coldair kit is kind of pointless.
Old Jan 28, 2005 | 09:45 AM
Black 30th SS's Avatar
Save your money, I wasted money by buying one. I regret it.
Old Jan 28, 2005 | 10:46 AM
SS MPSTR's Avatar
I couldn't agree more.
Old Jan 28, 2005 | 10:51 AM
Red96Lt1's Avatar
Headders, don't buy a MAF
Old Jan 28, 2005 | 12:24 PM
kcshaner's Avatar
I am at 561rwhp on my stock MAF and my tuner still tells me not to upgrade it, so that should tell you something.
Old Jan 28, 2005 | 01:11 PM
NOMAD's Avatar
You'll see HP gains of a CAI over a Ramair
-Shannon
Old Jan 28, 2005 | 02:55 PM
96capricemgr's Avatar
The calibrations for aftermarket MAFs are unknown which means you can't set the pcm to be able to properly interperet the airflow so it can make accurate fueling commands. The TEMPORARY gains SOME see from them are a result of leaning out the AFR because stock is too rich, the O2s will learn out the gains and when you get too the point of proper programming the MAF will still be underreporting airflow too a pcm now setup for proper AFR and now you end up lean. Drivability problems become downright common occasionally worse happens much worse. If you get too the point of your stock MAF being a restriction(see kcshaners post) then you will be spending lots of time on the dyno so you might then and only then consider porting the MAF it will take some dedication and knowledge too get the calibration back in line once you start carving which is why it is not a recommended thing too do but those with radical combos and dyno time to redo the tuning can play with it.
Old Jan 29, 2005 | 12:51 AM
Huntr1117's Avatar
What about removing the screen from the stock MAF?
Old Jan 29, 2005 | 10:41 AM
SS MPSTR's Avatar
I kept the screen in mine. It does serve a purpose.
