Maf translator
Old Dec 24, 2005 | 07:40 PM
94 BIGRED's Avatar
Lightbulb Maf translator
ok guys i was just given a maf translator. What adjustments should i do 2 it a/f wise. Here is a list of mods done.
Hooker L/T, 2 1/2 x-pipe trua dual, shift kit, 3200 10" hughes , hughs 153 teeth flexplate, converter,vortec elbow with k&n cold air kit, air foil, egr blockoff,msd 8mm wires, and walbro 225 lph inline fuel pump!!!!!!!!!
Old Dec 24, 2005 | 11:48 PM
zx1216's Avatar
Re: Maf translator
i don't think many people on here use them too much since tuner cat is only $90 and you can do so much more with it... But if you want to try it out i would recomend reading up on it and puting it on a dyno with a wideband o2. Get a baseline and go from there untill the a/f is where you want it.
Old Dec 26, 2005 | 08:38 PM
96capricemgr's Avatar
Re: Maf translator
A knowledgable b-body guy swore by these things with his 11 second heads/cam/spray car then one way or another he was convinced to try a pcmforless tune and went .3 faster with traction becomming a problem again where it had been deadhooking. A Translator is a halfassed tool that should only be used on vehicles where you can't access the pcm much less access it as cheaply and easily as you can on the LT1 vehicles.
Old Dec 26, 2005 | 09:12 PM
Coop1's Avatar
Re: Maf translator
Where are you getting tunercat for $90?
Old Dec 26, 2005 | 09:37 PM
zx1216's Avatar
Re: Maf translator
i think thats what they run off their web site, maybe that is for obdI, i think the obd II is a lot more.
Old Dec 27, 2005 | 03:18 PM
Re: Maf translator
Yes OBD1 tunercat is $70 for the program then $20 for the definition file.
Old Dec 27, 2005 | 04:44 PM
Coop1's Avatar
Re: Maf translator
What was there address?
Old Dec 27, 2005 | 07:01 PM
Re: Maf translator
www.tunercat.com
Looks like the OBD2 version with definition file is $380 this will allow you to not just play with fueling but rev limits, spark, in an A4 shift points and TCC lockup, believe it can be of help with CAGS in an M6 car etc.
Depending on whether emmisions testing is a concern a lot of us swap to OBD1 pcms for cheaper tuning and logging software, some tuners find more power in OBD1 as well though I don't understand how.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
