MAF symptoms
Old Mar 12, 2005 | 08:09 PM
BrandonKeith's Avatar
Unhappy MAF symptoms
car use to not run, or start and die if i ever unplugged the maf, now it'll run without it.. the reason i'm asking is because at anything under like 1700rpms it's jittery. all gears, doesn't matter, and it kinda feels like it's going to go, then it gets sluggish, then feels like it's all good, then a lil sluggish..( all the go and sluggish is in the span of WOT for about 5 seconds until it hits about 4500 rpms and goes like a bat outta hell..) i'm thinking it's the maf cause my map is new and so are my o2's.. this just started happening 2 days ago when i got it outta storage.. it had no gas in it when i put it away, i made sure of that, i filled it up with some awesome gas as usual and a lil injector cleaner. feels like a rich issue cause it sometimes smells a lil rich.. that and it would never run before without the maf hooked up and plugged in.. it idles fine from what i'm seeing, just like it allways has. i don't know what the hell's wrong.. any ideas..
Old Mar 12, 2005 | 08:55 PM
Eff's Avatar
Eff
Re: MAF symptoms
Well, it definately sounds like a rich issue. Not necessarily the MAF though.
4th gens will run without the maf, if it was died on you before it'd only because it didn't switch to speed density fast enough.
Now I'm confused, this jittery stuff, is this with the MAF? If so does it do it without it?
Old Mar 12, 2005 | 09:12 PM
Re: MAF symptoms
yeah, with the maf off it does it to about 2500rpms maybe up to all most 3grand.. but will clean out and go all bad *** about 4-4500 rpms.. i don't know.. it's becoming very aggrevating.. i just wanna love my car again with out being pissed off about how it's running but i'm also getting now ses light.. i can't figure it out
Old Mar 13, 2005 | 01:16 AM
Re: MAF symptoms
so, does anyone have any ideas, or know anyone that might.. cause i'm getting really ****ty gas mileage because of it, and gas is to expensive for this crap
Old Mar 13, 2005 | 06:29 AM
Eff's Avatar
Eff
Re: MAF symptoms
Well, I'd start by checking the ses light
autozone does it for free.
93 RedBird
Nov 15, 2015 08:24 AM
Double aught
Oct 2, 2015 11:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
