MAF sensor voltage??
My SES light is on and I went to Autozone and had them run a diagnostic check on it. The guy said it was a MAF sensor input voltage low. He said the sensor is not bad so I don't need any parts and it should not be causing any problems other than the light being triggered. Is this true or should I worry about it and try to find the cause of the problem?
carguyshu
Jan 22, 2017 11:19 AM
